5w50 synthetic?
Originally Posted By: 52pu
One of my customers has a newer Mustang with the all Alum high HP engine and ford recommends 5w50.
In that case, you'll want either the Motorcraft or Quaker State. As far as I know, those are the only two that meet Ford's spec for the track pack Mustang. If it's not under warranty, I'd probably just use Mobil 1 0W-40.
Originally Posted By: dave1251
Originally Posted By: A_Harman
The Motorcraft 5w50 is so shear-prone, it probably shears to a 40-grade when you pour it out of the bottle. If that oil is run hard, it ends up a 30-weight. So why not start with a 5w30 that doesn't shear?
I do not know of many 5W50's that are not shear prone even Red Line shears in 5W50 grade.
Yes. If I had a need for a 50-weight oil, I'd go with Redline's 10w50.
Yep, if you need an oil with an HTHS of 4.4 (e.g. Mobil 1 5W50), I wouldn't target a 5W50 in the first instance.
Motul 300v.
I recommend this after research I have done with a boss 302 that requires this weigh. Its the only oil that did not shear after 3k miles. Its expensive......
Originally Posted By: g8atl
Motul 300v.
But what if Ford expects it to shear? (which they probably do, they tested it...)
I've been using Mobil 1 5w50 in my 07 GT500 for the past few years. Its virgin viscosity is lower than the Motorcraft oil and it doesn't shear as much. I buy it locally at Napa when it's on sale.
