Originally Posted By: rclint
Originally Posted By: BuickGN
My experience with a worn engine and I have lots of it is a thicker oil does help cushion things. Very noticable in the amount of noise it makes. On the extreme end of things was a rod knock that I nursed for a year on Valvoline 60wt until I had the funds to rebuild. On a 40wt I was afraid to stand next to the car with it running.
However the OP is talking about a good running engine, with no loud noises, nor any abnormal wear that he can tell. In your case I agree a thicker oil may work, however in the OP case, and from the information he gave I think sticking to OEM spec or close (he is already using an outstanding HDEO 5w-40) would be a good choice, however changing oil, different brands, weights, synthetic, dino, even mixing your own is a freedom we all have, tis what makes it all worth while.... Would you have gone that thick in your engine if it was in normal good operating condition, just high miles ?
A grade higher, yes. A few grades higher, not on a stock engine.
