Originally Posted By: BlueOvalFitter
Originally Posted By: ARCOgraphite
Unless its a racing engine I think most modern engine run a bearing diametrical clearance of 0.0005 - 0.0020 - so that should not dictate grade. More toward piston controlring/skirt oil management, rod/main bearing area, reciprocating mas at max rpm, oil pump volume, tappet blead-down rate, vvti oil porting/ assy return spring etc.
4 cyl length inline block/crank have a inherent runout and tol stack limits (static and DYNAMIC) where you really cant go tighter than .0005 on the mains.
Makes sense. But, you always here the 5W20 Gods say to use 5W20 because of "tighter clearances and tolerances." If those tolerances and clearances have not changed in an engine when it was spec'd 5W30 why use 5W20, other than a glimmer of better gas mileage?
Because motor oil has continued to improve as well over time.
Typically a companies 5W-20 is the same oil as their 5W-30 but with less shear prone VIIs. Plus the fact that viscosity of a 5W-20 at the end of the recommended OCI is likely higher than a 5W-30 of years ago.
Finally from a pure lubrication perspective it is usually best to use the lightest oil recommended by the manufacture. Even with the lightest recommended oil, the viscosity safety margin is huge.
Optional heavier oil grades has more to do with grade availability in hot climates. The heavier grades won't provide any better lubrication but the main advantages of a 20wt oil have been largely mitigated as have the disadvantages of the next heavier grade.
Here in NA the availability of 5W-20 and now even 0W-20 grades is universal there is no reason to use anything heavier.
