Originally Posted By: gfh77665
Any 5 or 0w30 will protect in the heat just as good as a 10w30 oil would.
I don't know about that. If it were true, there would be no more 10w-30 made. I would take a quality 10w-30 for high heat, hard driving any day over a 0 or 5w-30.
well if that were true then any car ran in the summer when it's hot out useing 5w30 would melt down and seize.
5w30 is what GM recomends and will protect fine in the summer heat,it's still a 30w when hot.
I don't follow your logic.
Whats not to follow????? a 5w30 will protect as good as a 10w30 in the summer heat,simple...many cars on the road today run it AND thinner.
I think my will to argue just went away.
good...
This is exactly why this site is starting to suck. You make false statements as facts instead of stating them as opinions. We won't even get into the ASSumptions and how you arrived at the conclusion that you did with the 5w-30 and engines blowing up.
All things being equal a 10w-30 is more robust than a 0 or 5w-30. It will typically have a higher HTHS and will stand up to extreme temps and loads better. There are hundreds of pages on this on this site.
The 0 or 5w-30 will offer nothing in the form of better startup protection unless the climate requires it. The only advantage you may get is better fuel economy during the warmup process.
Quit reciting this stuff you've heard on the internet like "most wear occurs during startup" and try and understand it.
don't let the door hit ya in the ars on the way out.
putting words in my mouth now pal?? i never said that,take a hike
He's right though. There are a LOT of unsubstantiated claims and OPINIONS posted as FACTS on here recently.
All of the REAL facts seem to get lost in a sea of [censored].......
