5w-40 synth in a jeep I6 2002
Sweden
Just bought 5w40 SL synthetic for the jeep (80k miles). The manual says 10w30, any API class, but I want synthetic for winter and there are no synthetic 10w30 at all here and the 5w30 is overspeced, hard to find an pricey. 5w40 synthetic is common.
Will the slightly thicker oil be noticeable in any way? This is an old design engine...
A 5w40 will probably work really well for you. Is there a reason you need it (towing) or just want to run a thicker oil? Either way a 5w40 PCMO/HDEO will not hurt your engine.
I have been running 5-40 Shell Rotella Synthetic in a 98 Jeep Wraingler with an I6 for three years now. Same oil for three years but very low miles each year. Runs great with not problems.
Going by the used oil analysis section, a lot of those Jeeps seem to do better on 40 weights anyway.
as in 5W40 or 10W40 or 15W40
The manual says 10W30. I have Pennzoil Ultra 10W30 in my 2001 Jeep 4.0L engine.
The 5w40 is a great choice for that Jeep. They are not that picky about oil anyway.
Mines had SAE30,40,5w30,10w30,10w40,15w40,0w40 and 20w50. Now @ 130,000 miles and running fine.
I've been wondering the same thing, and am considering the T6 Rotella for the GC.
I have been running Mobil 1 Turbo Diesel Truck 5w-40 in my jeep wrangler I6 for 4000 miles so far. I like it and have had no problem, and as far as i can tell it quieted down the engine a little. (easy to hear the engine with no doors or top.)
x2. Rotella 5w40 or Mobil 1 Turbo Diesel Truck 5w40 seem to be the preferred oils around here for the Jeep 4.0L. My 4.0L runs a bit quieter on a 40 weight oil.
ok, interesting. Then the low prices 5w40 it is. Just found out it is SM/CF and ACEA A3/B3/B4. Should be ok for that old iron.
