Originally Posted By: Brien
Wow, oil is getting expensive now!
I have a 2001 Galant with a 2.0. The manual calls for 10w30.
This same engine is also used in the Lancer. In that car it calls for 5w-20.
Would it be incorrect for me to believe that I could use 5w-20?
Brien,
When I had my Toyota Camry the manual gave me a wide range of oil weight to use based upon the region your in. I mainly used 10w30 but decided to try the 5W instead and it worked out well.
For I'd say it should be fine as the engine is the same. You'll see a small MPG increase if you drive easy too!
I've been contemplating on trying a 5W-20 myself in my 01' Durango V-8 but on another forum I was ill advised so I stayed with the 5w30.
Durango
Brien,
Durango
