Getting back to my question regarding the 51356 vs 51357 filters. They seem to be about the same, with the difference being the 51357 has an anti-drain back valve on the clean (ouput) side of the filter also. My question is, could this be a better filter choice vs a 51356? My specific application has the filter vertical mounted, thread side up (filter hangs). In theory, wouldn't this clean side adbv keep the oil passages filled better (from the out put of the filter up through the engine) and allow for quicker oil pump up during starting? or could their be any negative effects from using this style filter?
