507 approved oil with the highest VI
Southern Ontario
I was a forum regular until a couple of years ago. A new car gets the blood I mean oil flowing
. We have ordered a 2015 VW Golf Sportwagon (TDI, manual 6 speed). This will be my first diesel and turbo engine.
I know warranty requires a 507.00 rated oil for the VW recommended 10k mile, 1 year OCI but I am trying to search out said oil with the highest VI.
I know that Mobi's ESP 5W30 is highly regarded (and 507 approved). It has a VI of 164....similar to many of the 507 oils I have looked at.
The 0W30 ESP offering has a VI of 180 but does not have the official 507 rating.
Anyone know of 507 oils with a VI in say the...170s?
If it were my turbo charged DI engine, I'd be WAY more worried about TEOST scores than VI.
One of the best is Castrol Edge. I'd be pouring in some of the 5w30 variety.
Consider adding a catch can as well. This will help reduce deposits as well.
+1 Especially on the catch can!
Don't worry about the VI. The better base stocks always seem to have a lower number.
There was a good thread on this very subject not too long ago.
I am looking forward to having the option of using a 0W30 507 certified oil
Thanks. I havent been here in awhile. I will look it up.
For what reason? Are you subject to brutal winter temps?
There are tons of "specs" to consider when choosing oil. Some of them are TEOST, NOACK, viscosity, additive packages, VI, etc. etc.
Please don't take this the wrong way, but I think you're looking at some of the least important specs. When running a turbo charged DI diesel, I'd be most concerned with deposits and shear stability of the oil.
But that's just me.
How long of an OCI are you considering? What is your driving style? Short trip? Mostly long highway runs?
I have a 2010 JSW and it has only seen Mobil 1 ESP 5W40 since factory fill. I live in Wisconsin and as you may know, winters here are brutal. No problems starting even on the most fridged morning of -20 F below. Mobil 1 ESP 5W40 meets Mercedes Benz 229.51 spec, which is what they use for their diesels. If its good enough for a Mercedes Benz, it should be good for a VW TDI. I also like the fact that its on sale at least 3 times a year at my local NAPA.
Your diesel engine will last forever on whatever VW 507 00 oil you use.
That said, I agree to maximize performance especially cold starting, choosing an oil with the highest VI is the way I'd go.
If you can get the Mobil 1 ESP 0w30 I'd consider that. You may want to contact Mobil to see if they will back its use for VW 507 00 applications.
Too bad the VW 507.00 approved Shell Helix Ultra Professional AV-L 0w30 isn't available in NA as it would be a great choice with its 204 VI and low KV40 of 58.7cSt for a HTHSV 3.5cP oil.
Internet references seem to point to this oil "soon" to attain official 507.00 rating: Pennzoil Platinum Euro L SAE 0W30 (The first 0W30). And yet I can find no TDS for it.
_
The Pennzoil Platinum Euro 0w30 isn't available in NA anyways
so it's academic.
Just interested in seeing the TDS #s...see how it compares to that Shell Helix for example.
Of the likely available oils Mobil 1 ESP 0w30 would be my choice.
I see the well regarded the ESP 5W30 in retail but never the 0W30.
Mobil 1 ESP 0w30 is on the CDN Mobil website so presumably it's available being spec'd for BMW and Mercedes clean diesels. So the question I would want an answer to from Mobil would be if it can be used in VW 507.00 applications without warranty issues. At the very least the answer souod be of interest.
I'm shocked! LOL!
Hello!
I don´t know if they are available in North America, but here´s a list of oils 507.00, with VI around 170 or higher:
- Shell Helix Ultra VX 5w30 (VI=178);
- Liqui Moly Top Tec 4200 5w30 (VI=175);
- Shell Helix Diesel Ultra Extra 5w30 (VI=170);
- BP Visco 7000 Long Life III 5w30 (VI=169);
- Castrol Edge 5w30 (VI=169).
Regards.
Good news!
It looks like we are going to be getting this GTL oil labelled in NA as Pennzoil Platinum Euro LX 0w30:
http://www.bobistheoilguy.com/forums/ubb...04.#Post3675646
The only negative that I can see will be that it will be relatively expensive, $13-$15/qt from what I've gleaned from one Cdn Shell distributor.
Not sure about the others, but the LiquiMoly is readily available at the online TDI parts stores such as BoraParts (CascadeAutoParts) and IDParts. I think most Napa stores carry LM also or can get it next-day from the local warehouse.
I think the Castrol EDGE that is 507.00 certified is Edge Pro LL03 available at VAG dealerships.
Same here, unfortunately Mobil has discontinued the ESP 5w-40 and replaced it with the 0w30 which seems to be to be way too thin for a diesel application. I am casting about now for a replacement.
