Chassis/suspensionThanks for sharing, wagons are underrated here in North America.
I'm surprised to see the tensioner issue, didn't hear a lot of timing chain related issues with the gen 3.
What's your suspension setup?
H&R Sport springs (spring rubbers in fronts)
Bilstein B8 dampers
Golf R rear jounce bumpers
Euro Sport Street Camber Kit (-0.8 deg camber)
H&R front (27mm)/rear (25mm) sway bars
Tyrolsport front subframe deadset kit
034 rear subframe inserts
034 Dynamic+ front/rear adj sway bar end links
Superpro aluminum lower control arms (+1 deg caster/-0.5 deg camber)
034 Density Line engine/transmission mounts
034 Street Density dog bone pucks, upper/lower dog bone inserts, and billet dogbone mount
Superpro rear trailing arm bushings
Alignment specs: [front -2.0 camber/7.9 caster/0 toe] [rear -1.7 camber/0.08 toe]
