4WD
$50 site donor 2024
A trio from 5.3’s
Left to right:
Factory PF63 >> New gen XG10575 w/ 2x5k >> Primegard from quick lube
Left to right:
It has two 5k runs - which I did often on the previous …Thank you for sharing, with only 5,000 mi on that Fram, and it being a 20,000 mi filter how come it's already wavy?
I don’t like that look either - switched to UPF63R …
Likely to do these when the ACD’s are gone …
That’s it on the right - and also showing seam of PF63EGreat lineup & dime for size comparison.
Was the primeguard glued seam or metal crimped? Just don't see the media connection point. It's ok just checking.
Thank You! I see it now. It's a glued seam.
Great photos. Thank You for detailed cut and post. How many miles you run the UPF 64?A trio from 5.3’s
Left to right:
View attachment 159052View attachment 159053View attachment 159054
Thanks - I plan to do 2x5k … it looks like a Mobil 1 with AC Delco decals …Great photos. Thank You for detailed cut and post. How many miles you run the UPF 64?
Thank You again
Very good sir. Thank YouThanks - I plan to do 2x5k … it looks like a Mobil 1 with AC Delco decals …
surprising how much smaller it is too …Thank You! I see it now. It's a glued seam.
Yeah, UnUltra now4WD: that ULTRA is lil’ too wavy for me. N maybe I’ll roll dice and get a Endurance
The pleats are wavy in Virgin form (Unused).The Ultra pleats look extremely wavey with only 10K on it with a rating of 20K. Pleats should be straight. I will not be using it.
