Not always . Utility enclosures usually have a raised ring that encircles the bolt head . You need a socket .Vise grip pliers.
Just be careful you don't snap that cable off,if you use a cordless tool on it.The 5 point is the manufacturers way of preventing that as the spare tire in the compartment,not secured is considered a safety issue
Yes, the spare is raised and lowered with the 5-point tool - we have this on our Highlander. You can see it here around 50 seconds in...
Having the socket would make things quick and easy, but I did find a page where someone claimed Toyota switched to the 5-point because people were using impact guns on the previous standard bolt and were tearing up the mechanism (take that for what it is worth).
I'm looking for a 5-point (penta), square drive socket, one that measures 23mm (the mating bolt head has JIS identification). The only 5-point sockets I can find so far are "common" industrial 51/64" and 13/16".
Anyone know of a source for different sized 5-point sockets or is this bolt head design limited to a narrow range of sizes?
McMaster.comI'm looking for a 5-point (penta), square drive socket, one that measures 23mm (the mating bolt head has JIS identification). The only 5-point sockets I can find so far are "common" industrial 51/64" and 13/16".
McMaster was the first place I checked. They only have two sizes; 51/64" and 13/16" which both are close to 20mm. These are too small.McMaster.com
