Originally Posted by RayCJ
Hint: When running those small generators, if it has two, 120V outlets (or 2 banks, of 120V outlets) try to split the load across both sets evenly. If you plug one extension cord into one outlet then, power all the devices from the end of that extension cord, the load on the generator will be unbalanced. When those small engines run unbalanced, their speed governors have a hard time holding at 60Hz and they will burn fuel inefficiently.
If necessary run two sets of extension cords, each plugged into one of the 120V outlets and power the loads evenly as possible across the two lines.
Ray
If it has the 120/240 switch though and you flip it to 120-exclusive mode it should combine them evenly.
A single-cylinder 3600 RPM generator is already a little off because of the 4-cycle motor only making power every other revolution. Beats letting the fridge get warm though.
Ray
