None of the 960s had variable intake. As far as the low end torque difference between the 180hp and 200hp cams in the 960s 6 cylinder, it has been blown way out of proportion. Volvo created this graph comparing the 200hp and 180hp 960 engines. 92-94 200hp is on the left, 180hp 95-98 is on the right.quote:
Originally posted by Winston:
As far as the older Volvo, there was something different about that older 960. I think it had no low end torque. Plus, doesn't it have variable air intake?
Source:
http://www.volvoclub.org.uk/tech/V90Specifications1997.pdf
As you can see the difference is not that great. Volvo claimed the 180hp cams were geared to american driving habits. I think it had more to do with stricter emissions regulations that were introduced with OBD2. They continued selling 960s with 200hp in Europe to the end of production in 98.
95+ 960s use a shorter final drive ratio. 3.73 vs the early 960 3.31.
I would take the 20 extra hp any day. I know of at least 2 95+ 960 owners that have swapped early cams in to their car for the 20hp gain. Nobody is swapping the other way around. If you really want more low end torque, the 960 came from the factory with adjustable cam gears. I advanced my exhaust cam about 6 degrees for more low end torque. The car takes off like a V8. Top end is about the same.
