The Acura Vigor from 92 to 94 came with a 5 cyl inline, about 175 hp. In retrospect regret not getting one of those back then, having driven one with a stick shift. It was kind of a blast driving it thru hilly terrain.
I could be wrong ..but I sware that 70's Ferraris had somewhere around 400 hp in under 5 liters ..and MB routinely boasted of greater than 1hp/cid(or 61hp/liter) during the same time frame.quote:
From what I have observed. You cannot get more than 60hp per liter without one or more of the following; Variable valve timing, variable intake, turbo, supercharger, etc. Anyone know of any exceptions?
Dodge Neon 2.0 DOHC and later SOHCquote:
Volvo 2.5 x 60 = 150hp.
All Mitsu V6 engines follow this rule.
Chrysler Hemi 5.7 x 60 = 340hp
Many cars get less hp per cylinder. Anyone have an example of a stock engine that gets more than 60hp per liter?
No - the Impreza RS has the same EJ25 2.5L as the Legacy and Outback. I know that the EZ30 3L H6 in the current Legacy/Outback has VVT, as well as the STi Impreza, but I'm honestly not sure about the other turbo models in the Forester/Outback/Legacy.quote:
Originally posted by Palut:
Does the Subaru Impreza 2.5 RS' 2.5L engine have variable valve timing or a variable intake? I know its not turbocharged. It produces 165 hp and 166 lb/ft of torque.
However, on allpar.com I found the following info.quote:
150hp/2.0=75hp/L
No variable length intake, no VVT. Just a simple, cheap engine designed more than a decade ago.
95-00 Neon DOHC produces 150HP. Its **** quick too with only 2400lb to push around.quote:
Right, and it produced 133hp.quote:
99-00 DOHC does not used variable intake.
That's a bad assumption to make. Many racing engines have topped that figure. BTW that figure is very close to the "1hp per CI" that people have been talking about for years. The Current corvette engine, the LS2, tops that figure by over 10%, even with OHV.quote:
Yes a Volvo I6 92-94 201 HP from a 2.9 liter naturally asperated 24 valve. That works out to 69.3 HP per liter. My 97 960 only makes 181 hp due to a Volvo cam change made in 95. It still makes 62.4 hp per liter. 172 ci making 181 hp isn't bad. 1.05 hp per ci.quote:
I wish.... 4.0x60 = 240hp...darn. Stock 4.0Ls have as little as 177hp - 195hp. My ZJ came with a 190hp varient without a dual lobed cam so the max torque is at 3800 rpm, opposed to 3000 on the newer models. I have an exhaust system and some various mods that push the power to about 210hp.quote:
They get that power with a different head and nicely tuned dual intake runners. I'm waiting for brianl703 to chime in... he knows alot about those engines. I guess thats variable air intake... but its not variable valved timing.quote:
I want to know how Ford gets 80hp/liter in their Contour.
Ford Contour SVT
200hp / 2.5L = 80hp/L
As far as the older Volvo, there was something different about that older 960. I think it had no low end torque. Plus, doesn't it have variable air intake?
Would've been kind of an anchor for large ships, with all that cast iron , donja think?quote:
Originally posted by cousincletus:
I would have liked to see a V-12 made from the Chrysler slant six.
You forgot V-10's.quote:
Originally posted by olympic:
An engine is naturally balanced if the angle between firing sequences is a full multiple of the angle between the cylinder banks. So on a 6 cylinder engine for example, you have a firing sequence every 120 degrees. So the only 2 naturally balanced configurations are: 60 degree V6 or I6(360 degree bank seperation).
Other naturally balanced engines are: 90 degree V8, 60 degree V12, I4, I5, I6, I8, flat 4.
