5.7L Chevy is a sludger too??
North Carolina, USA
Just purchased a 1995 2500HD for an additional work truck. The thing was skipping on #5 and a compression test showed what I pretty much knew. Time for a valve-job. Pulled the intake and lo and behold it's sludged. A valve-job just turned into an engine overhaul. Well, I was looking on Amsoil's webite for a filter for it and they have a note about the 5.7 being a sludge-prone engine and they advised factory service schedules. The fella I got the truck from swore he did his oil changes and based on the lack of wear on rocker arms,mains,cylinder walls I believe him. Anyone else had an issue with a late-model 5.7L making dino-preserves in the engine? Goo thing parts are relatively cheap for these old things.
Some 5.7's suffer from IM gasket failures, I think, and THIS is what causes sludging - slow coolant seepage into the oil.
I don't think the engine design makes it a 'natural sludger', like Toyo 3.0's and the like.....
Perfect answer. Spot on!
The old 350 design is not a known sludger,Ive had 4 with no issues.What about the owner before him?,it is possible also to have zero wear problems on these engines despite oil abuse.I would debate the need for overhaul unless oil consumption or rods making noise is obvious.
He was the original owner. No coolant ingress into the engine. It's getting an overhaul. Not about to spend the time trying to patch a sludged-up motor.
This will be the third late-model(1990-up) 5.7L I have overhauled in the last few years. All of them were full of hard crusty sludge. I just assumed it was neglet but Amsoil's reccommendation sheds a different light on it.
Agreed- its much like the 1990s Dodge 5.2 and 5.9. Engines that had existed for decades and were SUPER easy on oil were suddenly throwing crankcases full of grunge. In the Dodge case, it was an intake plenum gasket allowing mixing of crankcase air and air/fuel mix (and exhaust gasses in the case of EGR engines) In the Chevy case, it was a change to intake manifold gasket. In either case, its fixable but still an aggravation.
i've seen a 5.7 sludge like no other a guy ordered a reman engine and the core he brought in was thick with sludge, but i think it was neglect or maybe a coolant leak
None of these engines are known sludgers i owned tons of them over the years..IF there is a build up it's a maintenance oil neglect thing.
Well, if that's the case, why is Amsoil calling it a sludge prone motor? The intake leaks were prevalent in the 5.7L Vortec engines with the plastic intake manifolds. The earlier 5.7s with the aluminum intakes did not have high failures of intake gaskets.
All engines will sludge with lack of maintenance but you don't call it sludge-prone for that reason.
the 5.7 tbi engines sludge up due to the pcv system plugging up.
and the img leaking causes the same.slow coolant leak.vortec worse but the tbi does it too.
Originally Posted By: jdog
gm realy mesed up whin they stoped using the good old 350!
Why? The LSx family is better in every possible way.
