5.7 Chevy Engine Questions
CCI
New Mexico USA
1994 Chevy 2500 with 202,785 miles.
What should the oil pressure be at operating temperature highway speeds?
What's a good oil to run in an engine of this type and age?
I think it’s going to vary quite a bit depending on wear. 40-60psi would be fine. Pretty much any oil from a 30-50wt. Maybe tailor the weight to the oil pressure and application
It should definitely be around 40.
LOP at idle when hot also indicates issues, maybe with loose bearings, bearing wear.
Still it can run for years like that, until it doesn't.
Gauge says 30 psi at highway speeds, operating temperature. No idea if gauge is accurate.
Just bought it. It has a bit of a knock at cold startup that goes away quickly and it feels a little more like a 4.8 going up hills but it runs fairly well for its age.
I will try a 10w-40 and a new filter and see how it does.
Thank you all for the response.
The startup knock is probably piston slap which is very common when a SBC (or most V8s) gets some miles on it. Not a huge deal. The pistons swell a bit as they warm up and the noise goes (mostly) away.
40 grade oil is a good choice.
  • Like
Reactions: wlk
Noise on startup that goes away might be piston slap. Which is much better than a rod knock.
I've got a 1990 C1500 with the same engine and similar mileage , I run 15w40 in mine. Hot oil pressure on mine at idle is around 46 psi and around 70 psi at highway speed based on a mechanical gauge and not the 35 yr old factory gauge.
Piston slap was more of an issue for the earlier Gen3 (4.8/5.3) engines, not so much for the outgoing Gen1's (5.0/5.7).
Agreed. I have never seen or heard of piston slap on the SBC. LSx, definitely, especially the earlier ones like the LS1/LS6, and the 4.8/5.3/6.0 engines derived from the LS1.
I have a SBC 350 with unknown miles. Installed a melling high volume pump. With 4qts 5w40 and 1qt 20w50 in see about 60psi cruising, and 25-30 hot idle at 90⁰ ambient.
I replaced MANY Fleetwood Gen II LT1's for piston slap when I worked at a Cadillac, Fewer Gen 1 Vortec's in the Escalades....But those owners tended to be oblivious to it & the mechanical fan masked it to a certain degree.
At the time GM treated Cadillac warranty claims differently than other divisions, They rarely denied or kicked them back.
That is interesting, I wonder if any other manufacturers do the same?
Follow-up report: NAPA Gold 1061 filter with the drain back valve helped greatly. It still makes some knocking noises at cold startup but nowhere near as bad as before. With fresh NAPA store brand (formulated by Valvoline) 10w-30, the factory gauge is showing 35 psi at operating temperature highway speeds, pretty low at hot idle.
At some point I may install a mechanical gauge, I don't think the factory gauge is likely to be very accurate the way it fluctuates.
My 98 with the 5.7L has piston slap on a cold start up and I bought this truck new and have always done 3,000 mile oil changes. Truck now has 146,000 miles on it. I guess I got unlucky.
  • Like
Reactions: wlk
Have you tried different oils in it? It might not matter ultimately, but my 4.8 is quieter with some oils than others...
Cold start noise is probably piston slap, had it in my 93 5.7l c1500. I run 5/10w40 in mine year round. Pressure is usually 30ish at freeway speeds and under 20 at idle.
