Good call. I'll check when I get home. Totally forgot lol.
I'm going to pull the transmission and replace the gear set Saturday morning. At least Bishop is fairly close. Living in Bedford isn't too far away
Going to be rear frustrated this sound comes back in 5k miles.
My plan:
1) check cooler flow, pull rear oil fitting and turn truck on. Will record flow with video. Assuming it's good
2) pull trans and disassemble
3) clean case back out with brake clean.
4) remove bushing from center support and double check to make sure center support oil passage way is free of debris.
5) replace center support bushing (not quite sure how I'll do this)
6) install Output shaft onto planetary.
7) check end plays of stack up to the center support.
8) reinstall and send her home.
