Alright, so I did have the 15 thou thicker sonnax forward hub washer and used that. Re did the stack up and with a 90 thou front pump shim, I have 13 thou of front end play and 8 thou of rear end play. Also have ~12 thou of reaction carrier to center support end play.
Also have rollerized the output, the forward drum (with the extreme duty sonnax piece) and input billet shaft.
At this point I think she's ready to go together for real. Currently waiting on new sealing rings for the input shaft.
I had the HD2 kit on it but have switched to the internal dual feed mod by removing the center seal in the drum and punching a cap plug into the case. I'm switching to the transgo OEM replacement separator plate. I did NOT block off the accumulators but do have the springs that go in them for the HD2 kit. Will probably not open the hole feed holes as much as I did on the HD2 plate since the 1-2 shift was a bit aggressive and the 2-3 wot shift when lockup was engaged was nuts (triple disk tcc) and could chirp tires behind a tune only LQ4
It's a truck that will be getting heads cam and turbo soon but is my tow pig that I occasionally daily.
