Corrected an issue. Now here's what I have. With the (starting from bottom of stack up) bearing, sonnax hub, .061 thrust and at the stator thrust I have the thinnest selective (black plastic) .0575 and the pump is lacking .041 from mating to the case gasket. So in theory to get to where I need to be with this selective I need to take the .041 and .0035 off of one of these locations
Correct?
Previous thrust measurements are moot . Found that the big bushing in the new overrun housing was too proud and was interfering with
That step. I'm going to restack the stock stuff back in it just for a comparative base.
Correct?
