- Joined
- Oct 31, 2025
- Messages
- 138
I found something interesting when I started to disassemble the 93 4l60E core that I plan to rebuild for my truck. Here are a few casting numbers: Transmission ID: 3KKD1544 (1993 K-series, 5.7 V-8), Valve Body Identification Number: 8678393, Pump Identification Number: 8682132 (Non-PWM), Torque Converter Number: 2017467482 (06/12/23, GM33CW).
The 1st thing I noticed was the fact that it has been gone through before, the newer converter gave that away. Endplay (rough measurement via MK 1 hand/Eye testing apparatus) seems to be “close”. Seller had mentioned that 3rd gear had “gone away”. I performed a stomach pump and found burned fluid and evidence of lining material in the pan, but no hard shrapnel. I then popped the servo in order to remove the o-rings, then reinstall and check band clearance. In the process of doing this, I came across something interesting. I immediately noticed slots that had been cut in the steel cover and wondered if I was holding a corvette (.74 ratio) servo. Being my first time in a 4L60, and lacking information on servo casting numbers, and noticing what was to me, a horrific amount of slop between the servo 2nd piston and housing bore (absolutely NO drag felt from the sealing ring to bore interface) I did some measuring with my dial calipers. I found the following: while the second gear housing (casting # 8642115) I.D measures at 1.792, (which leads me to think “corvette” servo, the 2nd gear piston (casting # 8642093 AC) measures at 1.755 O.D, and incidentally, also fails the “fingernail method” of surface roughness calculation of the oem machined surface.
My questions are as follows:
Any information is greatly appreciated! I hope you all had a great Christmas, LOTS of leftovers, and have a great New Years!
- Do these casting numbers correspond with Corvette servo numbers? (the dimension of the 2nd gear housing supports this).
- Is this amount of slop between the 2nd piston and housing acceptable? To me, this amount of clearance (.037”) seems to be just begging for leakage.
- The casting number on the 4th piston appears to be 8642482 and I need to know if than number denotes a stock 4th gear piston, which is what I desire.
