Originally Posted By: Reelizmpro
Hmmm the distributive rule of algebra? The reason they remain is because it shows you need to add 9+3 before anything else...pretty important step. The problem is sloppy math. Take it step by step. Write the problem on paper and show each and every step. Get rid of the parentheses in the proper manner. The parentheses remain until the expression 2(9+3) = 24.
Please understand the difference...
2(12) shows multiplication through distribution. Gets priority.
2*12 shows simple multiplication only.
note: there are no multiplication signs in this problem so don't add any.
Now you are saying evalute inside the parenthesis first. Which is what I've been saying. 2(12)has no distribution and becomes simple multiplication. 2(12) means the same thing as 2*12. Even if I accepted that 2(12) is multiplication through distribution, that does not mean it takes precedence. So working left to right dividing 48/2 takes precedence over mulitiplication to the left. Now you are arguing implied multiplication 2(12) or "multiplication through distribution" takes precedence.
