There are many non-boosted 4 bangers with small displacement (1.6/1.8) that produce decent HP and last very long. The key is to do it right, but it ain't cheap.
Example:
Honda Civic Si/Delsol with 1.6L VTEC, 140HP and has a gear ratio that is 4000rpm at 70mph. It is designed with long rod, short crank to keep the power band high (no torque below 3500rpm) and very short gear ratio. Can easily last 300k without problem. Integra with 1.8L VTEC that goes from 170 (GSR) to 195(Type R) HP is another one, easily last 300k without problem and is the most reliable Honda out there (more reliable than Accord and Civic).
To make it durable you have to get good design, like oil jet to cool the piston bottom, moly coat piston skirt, variable valve timing, oil cooler, high silicon alumnium alloy piston, AND HIGH PRECISION PARTS. You can't expect to get an engine design for low rpm to constantly run at high rpm and expect reliability, and you can't expect an engine design for high rpm to constantly run at low rpm and expect torque.
I am sure they can do a 4 banger right if they want, just that most consumers have a "got to get a V6" mind set. The big 3 sell displacement for cheap, and Americans love displacement, so thats what they are doing.
Example:
