I have a 2004 Mercury Marauder that has the 4.6 DOHC Engine, I am coming up on 30,000 miles. The owner's manual says to change the oil every 5000 miles.
I will probably be putting on 15,000 to 20,000 miles a year on the car, I plan on keeping an Amsoil EaO Oil Filter on for a year.
I have an AFE Pro Dry Air Filter, and I plan on changing the PCV every 30,000 miles. I will also be putting on a Catch Can.
The car does not see short trip driving.
I can maybe do 2 oil changes with the Pennzoil Platinum, running it out to 8000 miles, or I can do a yearly oil change with the Amsoil OW-20. Obviously the Platinum would be the 5W-20.
I went through the used oil analysis section and I only saw 1 UAO for a Marauder. I will probably have to get a used oil analysis done to see how long I can take the Amsoil OW-20 or Pennzoil Platinum out.
I also plan on running a Maintenance Dose of auto-rx after I finish this Clean and Rinse. I have heard these 4.6 Engines are good, but is there anything I need to watch out for.
If I did a yearly oil change with the Amsoil OW-20 would it be wise to change the PCV Valve out once a year.
I drive the car like a normal person, and I am averaging 23 m.p.g. I also use Amsoil PI once a year.
I know this is overkill, but I have a Filtermag on my Amsoil EaO Oil Filter, some people have said with the Filtermag on there I could probably get away with a Motorcraft Oil Filter.
I am open to suggestions from anyone with experience with these 4.6 DOHC Engines.
