Originally Posted By: tig1
You are making this difficult for yourself. If you would notice my earlier post on you thread that my friend is a service tech on these generators. The only oil he uses for his customers is Mobil 1 10w30, year round.
Also my daughter has a Generac 15KW unit and her tech also uses Mobil 1 10w30 for his PM work.
Change it once a year, unless you had a very long use time.
I figured I would add my "two cents" since I own a Generac 15KW and have used it during extended power outages. Mobil 1 10W30 is just "OK" in this application. Everyone uses it because it is commonly available for both Generator techs and homeowers. The problem I found is, that in 90F temperatures, it "burned off", the oil level dropped to below 1 qt (my oil capacity is only 1.7qt to begin with), and the generator shuts itself off in the middle of a power outage(after 48 continous hours). You then must refill the unit to get it started again (Your wife may not want to do this if she is home alone). To avoid this hassle you can do two things:
1) Use an extended capacity oil filter to increase the oil capacity. Generac makes one. I am using a Purolator. My oil capacity went from 1.7 qt to 2 qt.
2) Use a better oil for this hot application. My opinions in good, better, best categories if you want to use a 30wt oil, like the manual says:
Good - Mobil 1 10W30
Better - Mobil 1 Extended Performance 10W30, maybe Pennzoil Platinum 10W30 (I have't tried this one).
Best- German Castrol 0W30, Red Line 10W30, Mobil 1 High Mileage 10W30 (I haven't tried this one, but it has better HT/HS and flash point specs than the first two Mobil 1's mentioned). Minimal Oil Consumption issues for me with the GC and Red Line. I would throw in Mobil 1Racing 0W30 if you have deep pockets to buy it.
Hope this helps. Don't flame me too badly guys.
