3000 mi oil, LS1, Mobil 1 0W-40, 2000 Camaro Z28
Looking at the oldest report, in 2005 this 2000 Camaro only had 3600 miles on it? Or, was the engine replaced?
Did you run a fuel system cleaner in this run? GM V8'S spit copper for about 36,000 miles. This is normal and does not affect engine life.
The engine was replaced with a crate LS1, when I bought the vehicle.
Negative on the fuel system cleaner...
Originally Posted By: Marksman762
My report: This sample was taken during a rather harsh winter, during which my block heater quit working.
I had a problem with my motor cycle starting one year when it was very cold outside. I took a cheap hot plate and put it on the ground under the oil pan, connected it to a long extension cord, and had one of the house light timers set to turn on 2 hours before I started the bike. It worked.
I understand the block heater wasn't working, but any 0W-40 should, by virtue of its '0W', provide effotless starting down to at least -30C, AND decent metal wear numbers from quick oil flow.
I'm thinking I'll give the Penzoil Platinum 5W-30 a shot and see how that works... I'll let everyone know what I find.
