There are a lot of options there.
So let me ask this, as I have experience with minivans and SUV's:
1. Is vehicle going to be on asphalt all the time? Even on road trips? If so, is practicality a most important? Then minivan! Sienna is bit gutless with hybrid, but mpg is really good.
2. Are you going "off road?" Then clearance comes to play, and you won't get that with the minivan (the biggest drawback of my 2015 SIenna for our use, hence why I ditched it, among other reasons).
So, minivan: IMO, ONLY two options: SIenna or Odyssey!!!
SUV:
Minivan size and practicality: VW Atlas, but I don't like new infotainment that is all touchscreen. Oil filter is cartridge, but on top of the engine! Super easy! I had it. If you live in the West, my Atlas had issues with crack windshields. Some people have an issues, and some do not. If you going used, IMO, it is by far best SUV in that class bcs. practicality, size. Only maintenance thing is Haldex AWD every 40k needs fluid and cleaning of strainer (VW won't do strainer cleaning, but it is absolutely recommended. Strainer cleaning takes 15min).
New Pilot: Good seating position (finally), physical controls copied from previous VW Atlas (good thing). I drove TrailSport (VERY interesting if you are going bit off road) but engine is gutless as they added 400lbs over old Pilot and kept same power. 2nd, 3rd row and trunk, much smaller than Atlas.
Toyota Grand Highlander: Tight in 1st and 2nds row. Small seats!!! (same on SIenna!). 3rd and trunk comparable to Atlas. Grand Highlander has hybrid option. Generally, AWD in hybrid option is underwhelming and probably has the poorest performance of AWD options in the SUV class. Regular, non hybrid has really good AWD.
Pathfinder: Too small.
Hyundai/KIA: would not touch it with 1000ft pole.
Chevy? Gutless 2.0T, etc. But biggest trunk!
Subaru: Tight, CVT!
1. Did not know about Traverse 2.5. Does it come with that 10 speed that is shared with FORD?Chevy Traverse is a 2.5LT now with more horsepower and torque than the outgoing 3.6L V6. Plenty of power, but typical 4cyl "buzziness". That might bother some, others might not be bothered by it. It also has more power than the non-Hybrid Grand Highlander (which is also 4cyl turbo.)
The horsepower king of the group is the Grand Highlander Hybrid MAX. However that would well exceed the $50K limit.
The 2025 Honda PIlot and VW Atlas are identical in terms of exterior dimensions. The Honda has more room for passengers, the Atlas has 10 more cubic feet of cargo space. If you want passenger room you go with the Honda, if you want less passenger room and more cargo space you go for the VW.
Agreed, Hyundai/KIA (Carnival, Telluride, Palisade, Santa Fe, Sorento, whatever) and the Subaru Ascent would be the absolute last choices.
You are right, Traverse has biggest space behind 3rd row.My current 2021 Chevy Traverse and past 2019 Nissan Pathfinder had actual usable 3-row seating. The Traverse offers more rear storage with the 3rd row in use however.
I just came back from a 1500mi+ round trip road trip with our 2021 Traverse LS AWD. What an excellent long haul road trip vehicle it is. So comfortable. Excellent visibility, power, handling and great fuel economy for it's size and capacity. Ours has the 2nd and 3rd row bench seats. 8 seat capacity.
I bought our Traverse last January used with ~35K miles on it. It currently has 48K.
Super easy engine oil changes and all driveline fluids are easily DIY. I have threads on that floating around.
In terms of long term reliability? Who knows. Everyone has their experiences there.
The question is clearance. Pavement? Fine. And even that, if bike rack is on hitch can be an issue.If the third row will be used on regular basis and for longer trips, the a minivan all the way. They will also swallow just about anything snide the cabin, so they make a great utility vehicle as well.
I think ground clearance and rear tire wear when loaded are some reasons to get a Caravan with the solid rear axle.The question is clearance. Pavement? Fine. And even that, if bike rack is on hitch can be an issue.
I got rid of it primarily bcs. I was absolutely confined to pavement.
When you are getting out of driveway, if there is any grade, or you encounter a dip, you are scraping rack.
I think that would be too old for OP. Plus not sure in general about “reliability!”I think ground clearance and rear tire wear when loaded are some reasons to get a Caravan with the solid rear axle.
If I had to go van, I might be tempted to get a low mile, perfect condition pre-pentastar, or late pentastar Caravan for cheap transportation?
Do some research for the trouble spots and see how little you can get a good one for? For me, $40-50k vans are not going to happen, but people do buy them.
The air boosters solive the “problem” 100%.I think ground clearance and rear tire wear when loaded are some reasons to get a Caravan with the solid rear axle.
You don't mention if you need AWD/4WDFuture potential of buying a larger vehicle with 3 rows. I'm open to anything from minivans to SUVs. Sienna, Carnival, Explorer, Traverse, Ascent, Santa Fe, Odyssey, Highlander, Pathfinder, etc. all come to mind. Or others I'm not thinking of.
What I want: reliable and under $50k. And easy to change oil on (i.e. not a cartridge filter).
What would you choose? Let's think "new" even though we might end up with used. For the sake of argument.
