Found this interesting bit of info, makes sense?
http://www.camaros.net/forums/showthread.php?p=271539
Quote:
Ok the way it works is this. Say you have a 3000 stall convertor and you are going say 55MPH with your 3.73 gears. At this speed you would be turning around 2500 (depending on tire diameter). IF You now FLOOR the car, it would IMMEDIATELY feel like the car's transmission was slipping momentarily because the convertor has not gone beyond it's stall speed. A good rule of thumb is that the MAXIMUM stall you should run (assuming you are also running on the street) is 200-300 RPM LESS than whatever RPM you cruise at on the highway. For example I cruise @ 2800-2900 RPM so my suggested max. stall spped for my convertor should be roughly 2600 (which it is).
In the 496 example I cited earlier, if you pull away (say light throttle) away from a standing start and watch the tach, you can see that it momentarily goes to 3600 rpm not because the tires are slipping but because of the high stall convertor. On the highway the car feels as if you momentarily have it in neutral just prior to it "catching" in a sense.
Slippage does cause heat. Auxilary transmission coolers are more or less REQUIRED on cars with 2000 or more stall sooed convertors. Slippage also causes poor gas mileage. the 496 with the 3600 stall convertor gets maybe 6-7 MPG. My car with approximately 25 more HP gets 11-12 MPG. (yeah, I know guys it's apples and oranges but the point is high stall convertors KILL gas mileage for those of us interested).
I guess I would describe the effect of the convertor prior to reaching stall speed is the same feeling as if you were runnning a standard transmission with the clutch slipping. It is still engaged all right but you are not getting the full throughput of the motor.
Originally Posted By: pacem
In that case looks like the safest thing to do is to go with 3.23. It's a compromise gear, OK on both highway and in town. I had one before, although not with LT1.
