294k KM on 2006 TDI (BEW)... some lifter damage
I traded in my 2006 Jetta TDI last year with well over 100k on the ticker. Save normal maintenance items coupled with a bad DMF, I had absolutely no problems with the car.
My stance on oil regarding this car was largely formed by interacting with other BRM owners on Freds TDI forum. The cam/wear problems were a common talking point with these engines. Regarding oil, the following seemed to be the consensus:
1 - The most common element among cam failures seemed to be the use of a 5W-30 oil, even if it was 505.01 certified.
2 - Few problems were reported with 505.01 oils if they were of the 5W-40 variety.
3 - Many if not most people ultimately switched to a HD 5W-40 diesel oil that was not necessarily 505.01 compliant, specifically Rotella T6, Mobil 1 TDT, and Mobil 1 Delvac 1.
My personal experience - right after warranty was out, I switched to Mobil 1 TDT. I put over 100k hard miles on that car with that oil, and by the time I let go of it it was still getting 44ish MPG and was pulling as hard as the day I bought it.
FWIW...
FWIW...
100k miles is nothing, and unless you pulled the valve cover off and inspected it, pulling hard and good mpg means nothing.
I just sold my 2004 TDI Beetle last month, original owner was my aunt and it had 176k when I sold it. It too "pulled hard" like brand new and ran fantastic with great mpg, but I pulled the valve cover and the cam was toast.
Time for that hunk of junk to go.
VW's and broken cams seem to go hand in hand.
Originally Posted By: Brons2
Some on TDIClub have speculated that CJ-4 synthetics such as M1 TDT work better than the 505.01 in PD engines...
I know lots of TDI PD owners switched to CJ-4 oils, specifically 5w40 oils such as TDT or Rosella T6. I don't know as if they are better, but the reports are that they are at least as good. The CJ-4 rated oils seem to be more robust than the VAG 505.01 rated oils.
I think its quite safe to say that hdeo of the ci+4, cj type
are more robust than the passcar oils even if they carry a vw501 sign. Many poeple have had great succses with these oils in hard cammed v8´s, vw pumpdyse engines etc.
And since they are way cheaper its a no brainer to me..
i would use hdeo.
