Decided to change the front diff fluid on my GM SU5 axle 2024 Sierra 1500 with 13k miles. Replaced with Amsoil 75w-90. Not a fan of more fuel efficient GM 75w-85. Anyways I noted the fluid looked fresh but was very cloudy. You can see some white colored ripples on the pan when it dripped. I use my 4WD or Auto mode (basically AWD light 4WD fuel efficient) when it rains hard or snow fall in Minnesota winters. Should this fluid with condensation be normal due to my location. Sounds like that combined with low usage seems to give it less chance to heat up and burn moisture out like the rear fluid. Recently did rear diff and it was not like this. Pretty clean honey color. I think this diff was under filled too from factory because the fill plug magnet was clean. Only the cover glued on rubber magnet has some material.
