Mobil 1 5W20
Motorcraft oil filter
Some degree of fuel dilute
Ford did away with that on the 1.5 and put chains on them. Thankfully. Right now we are waiting to see what they will do with the 1.0s with that belt under the recallGood call on changing the oil early at 800 miles. Does this engine have the wet timing belt?
Why, the oil did it’s job quite well considering the fuel dilution.Engine could use a 5w30 to soak-up some of that dilution.. Being a Ford product, I'd run Kendall or Motorcraft full synthetic next.
As always, UOA results do not reflect cylinder bore, piston ring, piston, cam component, chain, pump or bearing wear rates. For that, physical measurement before and after are required.Why, the oil did it’s job quite well considering the fuel dilution.
Higher oil pressure may improve oil control ring effectiveness?Why, the oil did it’s job quite well considering the fuel dilution.
Why?Good call on changing the oil early at 800 miles.
Because not everyone can be a race car driver so we have to fill our time with more boring activities.Why?
826 miles...probably would last longer if they did it at 752Because not everyone can be a race car driver so we have to fill our time with more boring activities.
