So i'm finally assembling the timing cover on my 22r.I ran into a problem.which way does the oil pump gear go?The one that goes on the crank.Yes, i tried googling it but it doesn't say which way or een have a pic of the crank gear.Thanks
If i understand your question...the gear drive to the pump? It does not matter.
Use some Vaseline or STP in the pump when you assemble it, it helps to prime it.
The gear is something like this.This is obviously not it,but it has the outer gears like this and it has a little offset to the side like this one but a lot less.It has splines on the inside.http://www.ebay.com/itm/NEW-DuraTrax-Pinion-Gear-Steel-16T-DX450-Motorcycle-/290579936164?pt=Radio_Control_Parts_Accessories&hash=item43a7e9f3a4
DUH! what i finally realized was that the entire pump goes on the outside of the timing cover! The gear i was referring to was the one inside the pump.I thought that the small pump gear went in before the timing cover.Sorry for all the confusion.
