210,000km engine oil?
Queensland, Australia
I bought a Suzuki Sierra with 210,000km, I have no idea what engine oil it has been running. Factory recommendation is 10W-40 as temps here range from 5°C to above 40°C. I can get 15w40 mineral or 20W-50 mineral or 15W-50 semi-syn.
What brand of oils do you guys have there? Pretty low miles engine, 40 weight oil should be more than enough.
If you have a supercheap nearby, try this for 5-6000KM and keep an eye on consumption. It'd probably be perfectly happy on 15w40 too if you already have some.
If it's using a lot just bump it up to homebrand 20W-50, can't imagine this thing set you back too much?
I'm a fan of synthetic. Locate a half-decent automotive shop (Supercheap, Autobarn, Repco etc) and buy a 10W-40, preferably synthetic. 210,000 is getting on a bit but if it's been looked after it should still be in good condition, If it burns oil, go thicker, but start with 10W-40. Don't go thicker unless you have to.
If it were my car, it's be just about teh right time to use 15w40 Delo
210,000km isn't really that much in the grand scheme of things. Use what your owner's manual recommends. If you have burning issues, step up *a* grade (i.e. xW-40 to xW-50).
If you're looking to go 10w40, 15w40 or 20w50 - take a look at Shell's Helix range of oils at KMart. A good quality product that happens to be the best oil-buy in Australia on a consistent basis.
