My snapper is 11 years old, model is RP2167517bv. walk behind,
standing behind the mower it looks like the shaft that comes out of the transmission has twisted itself off on the mower right side where the shaft goes through the frame bearing that holds this shaft (about 3 inches from the transmission itself). It looks OK where it goes into the transmission.
this is a short axle on the right side, maybe 3 inches long, the wheel slips on its end and wheel is held on by a nut. the shaft is round but has two long flat sections on it.
Do the shafts pull out of the transmission? can I order a new shaft? I can not find any info on the web about the transmission and these shafts? does anyplace repair them?
Thanks
Thanks
