Or, repair it. That's the better choice.15W-60 for my rear main leak, 30 just goes straight though.
Depends on how long you plan to drive it. I have bought many cheap vehicles and dumped a lot of money in them but I kept them long enough to get money back in form of no payments. Most of them I got an additional 40k. Always moved up in years although all of them were over 10 years old. Only after I got injury did I finance a 4 year old vehicle then traded it in for the Caravan since it had electrical problems. Typical GM.On a $500 car ? Not going to happen.
What kind've Honda and how many miles?
If a car has some slight leaks from gaskets or seals would a 30wt leak less? Or would the difference be insignificant?
Run the liquimoly motor oil saver. Get it hot after adding. Can be used every 20,000 miles. Recommend m1hm 5w30 or pphm 5w30 in conjunction
The "leak" is a combination of several things ( viscosity, temperature, pressure pushing against it, surface area of the leak, length/depth of the leak, capillaries, properties of the gasketing/sealing material, and their action and a whole lot more)
This is what I am trying to take into the equation also. Using a 30wt or thin 40wt in a car that calls for a 20wt would undoubtedly raise oil pressure. Would this increase in pressure be counter productive for the desired outcome? I guess only way to know would be by experimenting.
