20w50 in tranny ?
Originally Posted By: kmrcstintn
not a Harley owner, but I can tell you that all shared sump bikes (same batch of engine oil takes care of engine, transmission, clutch/primary) use 'common' motorcycle engine oil/heavy duty engine oil (Shell Rotella T or T6)...the major drawback is that the transmission shears the oil down quicker than bikes with separate lubricant sumps
Most Harley's don't share fluids and the ones that do don't share engine oil.
My 08 street bob has 3 holes therefore 3 different fluids.
I use shockproof heavy in the transmission,rotella conventional in the primary and rotella in the engine.
Originally Posted By: cycleman
I always used either Amsoil or Mobil 1 20w50 in the transmission of my 2008 Heritage Softail with no issues. Worked well and nothing on the magnet.
I used it too prior to shockproof however that bang going into first was painful. Ever since adding shockproof to my transmission that first gear bang is pretty much gone.
"not a Harley owner, but I can tell you that all shared sump bikes (same batch of engine oil takes care of engine, transmission, clutch/primary) use 'common' motorcycle engine oil ..."
Rule of thumb is that the larger/cruiser bikes have separate sumps while the more compact/sleeker sport bikes share a sump between engine and transmission. There are exceptions to this rule, I'm sure, but that's a good rule-of-thumb to know.
Actually non unit construction is the rare thing nowadays. Harley's are the aberration more often than not. Most large metric cruisers are indeed shared sump. Triumph, Victory, Honda, Suzuki, Yamaha, Kawasaki, and Indian all use shared sump unit construction in their designs.
One of my bikes (97 Sportster) only has two fill holes. Amsoil 20w-50 been used in both for a few years now.
Yes. Every sportster I've ever seen has a shared transmission and primary and separate engine oil.
The Harley big twins have separate primary,transmission and engine oil.
