20W50 seems excessive, especially with the upcoming winter.
But it doesn't make it ideal.Anything above freezing is fine for a 20W winter rating.
Ideal from a fuel economy standpoint.Like I said, anywhere above freezing is fine for an oil with a 20W winter rating. “Ideal” is quite subjective.
The other concern is the wear and tear from the oil not properly lubricating the engine fast enough. A few of the other mechanics I talked to said that the 20w50 on cold startups will cause damage.Yeah well considering the OP’s stated concern was his engine exploding, that’s not going to happen unless the starting temperature is below the pumpability limit of the oil. It’s not going to explode due to using a 50-grade oil.
No. No concern there at all. Cold start performance is dictated by the winter rating, and as noted above freezing is fine. All those “other mechanics” that are frequently quoted here don’t understand how lubrication happens in an engine.The other concern is the wear and tear from the oil not properly lubricating the engine fast enough. A few of the other mechanics I talked to said that the 20w50 on cold startups will cause damage.
Split the difference and use Mobil 1 0w-40 year round..... I have used synthetic 5w30 forever and just now started to notice that the oil was burning a bit.
The 20w-50 seemed like overkill to me.
Doubtful. Variable valve timing does not work like that and when correctly designed all it needs is oil to act as a hydraulic fluid, the ECU can see what the camshaft position is and open and close the VVT solenoid to get it where it wants to be. I've checked my Accent on the snap on scan tool we have at work and all of the values are what would be expected even running 15w50.My guess is you will be getting a check engine light with variable valve timing codes very soon.
Time to do your own oil changes!Yes, I'm in Wyoming. I really do not drive very far at all, maybe 50 miles a week with the occasional trip to Colorado on the weekends.
I honestly do not know if a thicker oil is needed. I have used synthetic 5w30 forever and just now started to notice that the oil was burning a bit.
Is this a trustworthy local guy? If so, it might be worth accepting what he says.
Is 20w50 "allowed" in the manual?
Feel very free to ask him questions. The jump from 5w30 to 20w50 is a bit wide with a lot of common grades in between..
conventionalDid you get a 20w50 conventional or synth?
This^^^^^^^^^^^^. + It's just, too, thick. Change it out when the temp starts dropping this Fall.You don't want slow drainback from the head(s) on a horizontally opposed engine that is known for flooding its spark plug tubes.
Plus - less oil cooling as another deficit to a 20w50.
OP will be OK till late Fall. It's right around the corner.
It will also be fine based upon the fact that no engine is damaged by a higher grade oil than what’s listed in the owners manual. You can damage it with a lower grade however. The only way the mechanic is a moron is if he uses an oil with a winter rating that is inappropriate for the expected starting conditions.I think your mechanic is a moron, but the engine will be fine based on the manual's allowance of it. Although that sure is a wide range.![]()
This is a waste. Again, as long as the winter rating is appropriate for the expected starting conditions there is no reason on earth to change that oil unless your only concern is a slight reduction in fuel economy.Been running n/a ej's for the past 7 years. Never needed to run anything but 5-30 9n them. Some have over 300k miles.
Step 1: throw the whole "mechanic" in the thrash bin.
Step 2: pick up a 14mm or 17mm wrench, oil drain pan, filter wrench at your local WalMart. While you're there get a 7317 oil filter and 5-30 oil and do your own oil changes.
Step 3: repeat step 1.
I'll agree to disagree. If this was a regular V or inline engine, I'd have the same view as you.This is a waste. Again, as long as the winter rating is appropriate for the expected starting conditions there is no reason on earth to change that oil unless your only concern is a slight reduction in fuel economy.
Hypothetically, what if a 75w oil was used? 150W?It will also be fine based upon the fact that no engine is damaged by a higher grade oil than what’s listed in the owners manual. You can damage it with a lower grade however. The only way the mechanic is a moron is if he uses an oil with a winter rating that is inappropriate for the expected starting conditions.
