quote:I always thought snow traction will improve with lower PSI? But again we have a snow day once every 10 years, sleet maybe once every 3 years.
...Nevertheless, I prefer a bit more pressure to get better fuel economy, tire wear, tire durability, steering crispness, wet traction, snow traction and only give up a bit of ride harshness.
quote:There are 2 situations: 1) The tire never gets down to the road surface and "floats" on the layer of snow. In this case, yes, lower pressure would be better. 2) The usual situation: where using a higher inflation pressure improves the tire's ability to penetrate through the snow (or slush) to get to the pavement, but once it does, the pavement has much, much better traction than the snow by itself.
Originally posted by Jonny Z: ....I always thought snow traction will improve with lower PSI? But again we have a snow day once every 10 years, sleet maybe once every 3 years....
quote:Higher pressure increases the overall stiffness of a tire. That reduces the wear rate. The shape of the tread of a radial tire is relatively insensitive to pressure increases, so the net effect (IMHO) is that a bit more inflation pressure improves the wear rate faster than the distortion of the tread leads to uneven wear. Put another way, even though the tread may wear unevenly, it still wears slower.
Originally posted by Quattro Pete: Higher pressure = better tire wear? What about the claims that higher pressure will lead to uneven tire wear, ie. the center tread wears quicker than the sides?
quote:I used to run higher than OEM (+3 to +5 PSI) in my patrol cars. I would usually wear the centers due to the high speed driving. I run a +3 at x degrees set up now and have very even treadwear. I currently have approx 25K on a set of Goodyear Eagle F1's and expect to get 5-10K more using this "formula".
