You are very kind - thank you - do note, mine is in a Tacoma, but I’m assuming it’s the same powertrain and programming.
@dlundblad mentions something on the prior page. Wheel/tire combos. The new gen comes stock with a 55mm offset, giving the wheel/tire combo about as much depth/dish as Walmart china. There aren’t a lot of quality wheels available for this unless you immediately go to stick (poke) them way out. If you look at the Toyota forums, 3/4 of everyone is using wheels made by Method, most of which use a 1” wider wheel with something like 30mm offset. There’s hardly anything in between which gives a bit more stance or looks without totally killing MPG and potentially steering precision.
I will occassionally play with wheel/tire combos and buy/sell until I get something I like. OEM take-offs are the jam if something works there. Their stock 17 and 18 black/silver ring wheels look very nice for an OEM, but could use a touch less offset to my eye. OZ makes an 18 wheel with maybe a 50mm offset, but only in an 18 and not a 17. 17 also looks better for a 32” tire. 18” wheels start getting heavy. There’s not much else out there unless you go for super-wide, big rubber and add-on fender flares. Maybe that will change over the next 5 years.
Note on MPG. (Tacoma) With 3 skid plates, rear bed rack, matching roof rack with fairing, a 9” tall rooftop tent, trimmed chin spoiler (removed half of it after stuffing it in the dirt a couple of times) and stock ride height and tires, I’m getting 21.7 right now, up from 20.6. If I take the tent off (just installed a hoist this week but haven’t had the time to use it), it was getting roughly 23 and a half or so, in hybrid AWD form. I’ve been pleased enough with the mpg. It does not matter if it gets regular or premium for MPG, though throttle response is better on high test.
-m!
