Excellent post. There's a few zerkies under the front shield most people never service. The 5w40 ff could be a Canadian thing.Factory fill is Delvac 15W40. Any decent CK-4 oil will serve you well. Duramax's are easy on oil. 2 of mine run Delo 5W40 year round and the newest one I'm trying the ultra low ash Delo 600 ADF 15W40. All are on extended drains and all sample well.
Userfriendly is right, diff levels are supposed to be 0.4 inches (10mm) below the fill plug with a level truck and oil hot enough that it will fall back down into the diff fairly quick. I'd advise against spill filling to the plug level. Grease it right away, they are pretty dry. Most zerks took 15 to 20 pumps on my new one.
Trans is Dexron ULV. Not a lot of options out there. Transmission is not user friendly from a service standpoint, and there's no dipstick to check the oil. Be careful what you put in it for oil if you do service it yourself. Lots of places say their universal or Dex6 fluids are okay, they aren't. The transmission is programmed to operate with the thinner ULV (~4.5 cst) fluid. It has a MASSIVE cooler on it so temps aren't an issue. I haven't seen mine over 155F yet.
Congrats on the new rig!
Defuel has never been mentioned before on bitog. I first read about in the 2013/14 Corvette engineering summary handed to me fromThere is a spill level plug on the bottom of the pan (connected to a standpipe inside) and a fill plug on the R side. Stupid thing is, GM says the fluid temp has to be at 170F to check it properly. It's painful to sit there and torque stall it that much to get the fluid that hot. So far I like the transmission except servicing it, then I'll take my 6 speed Alli's every time.
Weird about the 'upgrades', there is literally milliseconds of defuel per shift. One of the benefits of the ULV is the shift timing on these things is lightning quick. One of the reasons I mentioned the ULV is if you use a thicker 6 or 7 cst fluid in these things they slip and shift like crap when its cold. It's the only HD 10 speed issues I've seen at the dealer so far. But hey, the aftermarket loves to sell solutions for problems they dream up.
I forgot to ask you what's in the big green truck? A 16x645 EMD?Ya, the 6 speeds love a 6 to 7.5 cst fluid....Dex3 or 6 or TES 295 or the newest 668 fluid. They de fuel more than the HD 10sp, which helps them live forever like they do. Time will tell if the 10's are gonna live as long.
Yes, 5w40 for below 0 F. Gotta start this beast in Edmonton.Excellent post. There's a few zerkies under the front shield most people never service. The 5w40 ff could be a Canadian thing.
I haven't looked at the 10 speed yet. On a Ford Escape transmission there's a plug that you take out. With the engine at idle,
fill the transmission until the atf overflows and runs out. Obviously one of Ford's better ideas and their imput on the 10 speed
not having a dipstick.
There could be a fill to overfill plug on the "Allison Branded" 10 speed. ???
You're right about the ATF temperature. It takes a lot of hard climbing up a mountain pass on a hot day..... and I've never seen
90C.
edit; There's already transmission program "upgrades" for the 10 speed that increase line pressure and reduce the "fuel off"
time while shifting. IMO the HP & TQ race is hard enough on the tires and drive line without chirping the tires on every shift.
Add that to the lifted bro-truck with 37s and increased driveline angles and the weak link will break.
For the difference in cost - might be worth seasonal changes … 15W40 Delvac is now made with EHC …Yes, 5w40 for below 0 F. Gotta start this beast in Edmonton.
Neil Young said "Portage & Main 35 below".Yes, 5w40 for below 0 F. Gotta start this beast in Edmonton.
what is the meaning of EHC? FWIW Delvac is a " loss leader" at Walmart and BJ's wholesale clubs.. usually 14 and change at Walmart and 10 bucks a gallon in a 4 gallon case at BJ's when they have it.
TFL Trucks just posted a video on a 2024 Silverado.My 2024 gmc hd will be delivered next week. Which 15w 40 are you guys using?
Thanks
Jeff
