2023 C8 Z06 Corvette, Mobil 1 Supercar 5W-50, 1489 Miles on Sample, 9310 Total Miles
New York
Sample taken at 9310 miles.
1489 miles on sample only - no oil change.
Oil level found rising on dipstick by ~1/2 inch from full.
Oil capacity = 8 quarts.
1.46% fuel dilution = 110 ml of fuel.
Viscosity dropping close to 40 wt. range.
Curious if you live in a warmer climate. 10w or 15w may be something to look for if you live in warmer winter area to reduce Viscosity modifiers, which will reduce likelihood of Viscosity drop
Did you add any oil between the first and second sample? I've never seen Boron go up, only down. The only way I can imagine going up is if fresh oil was added to the mix.
Looks good. Do you drive it like a Corvette or a grandma?
Being I'm a responsible member of society driving on public roads, I try to be safe at all times. Seriously, the car is driven mostly highway typically between 85 and 100 mph with a few sustained moments here and there at around 120+.
Yeah, something to think about.
The first sample was drawn during an oil change. The second sample was after this oil change.
i would say there is more danger in driving it easy, than the motor oil
I run Mobil 1 Super Car 0W-40 on my LT4 equipped GM vehicles and the shearing after that low of miles is concerning. I do run Amsoil SS 0W-40 on my TRX and I rest easy knowing it doesn't shear during the 5K OCI.
Maybe go to Amsoil SS 5W-50 instead of Mobil 1 on your next oil change? I used Mobil 1 for decades and the Super Car formula is supposed to be the best street/track oil they offer. I'm disappointed. Good thing I don't run oil for long on any of my vehicles.
