For a 2022 Subaru Impreza which alignment angles (toe, camber, caster) are adjustable from the factory, without using any kits, adapters / modifications.
Also what are the factory spec ranges for the toe, camber and caster?
Subarus remained unchanged when I worked in a dealer with Subaru but that was from 2003-2013. If it’s the same, it’s rear camber and toe, and front camber and toe. Front camber adjustment is minimal.
I just got my 2022 Impreza aligned today at a local subaru dealer.
here is the printout. looks like the steer ahead was way off. Is this a result of front and rear toe being out? in my situation does camber play into it?
Did the tech do as best a job he could considering the only adjustable items are front toe and camber and rear toe?
