So another question. I am going to be changing the differential fluid on my 2022 Ford F150 9.75" rear end. Will be using a Lubelocker gasket. i am confused as to the torque values they specify for the stock rear cover bolts. I think they say 33 ft lb? That seems really high. Even a grade 8 bolt that size shows only 20 ft lb and I think Arp bolts are 22 ft lb. is this 33 ft lb recommendation why so many are snapping Fords bolts?
