2021 Silverado fluid changes
I just picked up a 2021 Silverado with the 2.7l turbo and 8l90 and was wondering if anyone had done all the fluid changes im thinking of a case of 12 Amsoil atf for the transfer case and the transmission and then I already have 6 quarts of 75-90 Mobil 1 full synthetic gear oil for both diffs is 12 quarts enough trans fluid for the filter change and transfer case or will I need more? And also does anyone have part numbers for the front and rear differential gaskets?
For many years - I backed off the bolts to make it drain - come back and squeezed a half quart 75W90 flush in - torqued - then filled with Delvac 1 … At least 4 Silverado/Tahoe units …
Delvac 1 can be a bargain on Summit Racing - such an interesting product that the Porsche track crowd loves what’s made for 80,000 lbs + beasts - but its proven in all of that stratosphere …
I always toss in something else to get free shipping …
I wouldn't touch the transmission fluid until I found out if your VIN includes one of the 8 speeds that had issues-and if a dealer changed out the fluid previously-which (according to GM) was a remedy.
https://www.motorbiscuit.com/chevrolet-found-fix-for-silverado-transmission-shifting-problems/
I did lol they said there no service bulletin or decals at all on the transmissions
What does that mean? I assume you are saying they have no record of transmission service? I assume they do have service records of oil changes? Most buyers have the dealer change the only during the warranty period.
Do you have a service history?
I asked if there were any open service bulletins or recalls on the truck and gave them the vin they said there is one for a fuel control module but nothing for the Silverado 1500 transmission's
OK-you don't have a service history. Wouldn't you find one informative?
I didn’t ask about a service history I only asked about the service bulletin mentioned above and any open recalls. One would be useful but unfortunately I don’t have one and can’t say that any used vehicle I’ve ever bought has had one.
