I didn't enter the info and this was the first analysis so ignore the comments. Ti is obviously the Castrol additive. Oil was dealer fill TPT 0w30 LL-01FE. Wear seems a bit high for about 3k miles. Combination of short trips and driven hard (when fully up to temp). Had exhaust side lifters and cam carrier bolts replaced per the common S55 cold start ticking issue about 1000 miles before this was sampled. Look at the viscosity
VOA (not mine) of the same oil here: https://bobistheoilguy.com/forums/threads/voa-bmw-twinpower-turbo-ll01fe-0w-30.371957/
Now running Mobil 1 0W-40. Will sample again in spring.
