2021 Escape Factory Installed Filter (Mann it would seem) 1983 Miles
Scruffy City
About 25% of the miles were all electric.
Yes it ended service way too soon, not my call unfortunately.
Looks to be a quality made filter. Use to seeing this type with four inlet holes, this one five. Very unique way they are formed on the Euro Mann.
As Escapes have had some "interesting" filter locations in the past, googled to see how this one was. "If" the same as yt I watched, not a bad location on engine. However, 15 belly pan screws/bolts had to be removed in prep to access it.
Thanks for c&p.
They should sell these in the stores over the Motorcraft ones. This factory filter is smaller then the parts department Motorcraft one. The larger OEM Motorcraft one rubs up against the coolant lines.
I do like this filter and yes it in minuscule.
This is a 2.5 and the filter is on the front angled down, no interference with anything, looks easy, could probably even change the filter from the top... haven't looked under, don't think there is a hole in the belly pan for oil or filter though.
Looks like a great quality filter. Seems similar to my OEM Mann filter on the 2018 Ford Focus Mk4 1.0 EcoBoost engine. Thanks for the c&p 🙂
