All of the Subaru 2.4Ts have oil coolers, so copper in these is generally NOT from bearings. At less than 20k miles, this is likely still normalizing even though it went up some here.Silicon from an air filtration issue seems a little high on one test but is lessening. The copper would be from bearings. I would try change intervals of 4-5k instead and recheck.
Good observation about the time-related component for copper pickup in oil, I hadn't considered that. It does seem to fit my most recent results. Also explains BlueSubie's general observation that shorter vs. longer OCIs don't seem to affect how long in total miles it takes for break-in related Cu washout to fully complete. Results of next UOA will be interesting.Copper leaches from the oil cooler, probably through a corrosion process. To a certain extent it probably happens even when the engine isn't running, but faster in warmer weather, and much faster when the engine is running. Assuming copper corrosion increases with time, temperature, and mileage, these results seem pretty reasonable.
1.5 months: 15 ppm Cu
6 months, over winter: 35 ppm
7 months, summer to winter, with 50% more miles on OCI: 57 ppm
If you had 20+ ppm copper from bearings, I think you'd see more of other metals like lead, tin, and aluminum. Lead is a touch high at 3 ppm on the OAI test, but 0 ppm with Blackstone. I wouldn't worry about it.
Your point is validated by my latest UOA!Copper leaches from the oil cooler, probably through a corrosion process. To a certain extent it probably happens even when the engine isn't running, but faster in warmer weather, and much faster when the engine is running. Assuming copper corrosion increases with time, temperature, and mileage, these results seem pretty reasonable.
It's a regular piece of equipment on the car, not an aftermarket add-on.What kind of oil cooler is that?
I am very well aware of that.It's a regular piece of equipment on the car, not an aftermarket add-on.
A better name for it would be "oil heat exchanger" or "oil attemperator" because it exchanges heat between the engine oil and the coolant. When the engine is starting up and the oil is below the coolant temperature, it actually warms the oil. At regular operating temps, heat is dumped from the oil to the coolant. It's largely copper on the heat exchange surfaces, which is why the oil tends to pick up copper.
https://subaru.oempartsonline.com/o...erm=4585581971566840&utm_content=All Products
My thinking is the same, though they should be trending down consistently and be in single digit numbers, unless there is something specific about this engine.If the copper spike isn’t due to the particular driving conditions, I think it could be due to the break-in wear metals not yet normalizing. It wouldn’t be the first time that there has been an odd spike in a Subaru uoa during the first 18k miles regardless of how many oil changes there have been.
yes. the other manufacturers use plain aluminum.I am very well aware of that.
But why is leaving copper when it does not do that in other cars with similar heat exchanger? I have it on both VW's and to does not have any issues around copper. Is there something unique about Subaru ones?
That is why I asked is there something specific, as regular wear should not look like that.yes. the other manufacturers use plain aluminum.
as i alluded in my previous post, “other manufacturers use plain aluminum” so that must mean subaru uses copperThat is why I asked is there something specific, as regular wear should not look like that.
I am just saying why I asked the question.as i alluded in my previous post, “other manufacturers use plain aluminum” so that must mean subaru uses copperdo a little research on the oil cooler. i almost bought one to retrofit on the K24 but chose to go with a hyundai unit due to the copper issues tainting UOA’s.
