Senchronize
- Joined
- Jun 16, 2023
- Messages
- 23
Thank you, the first thread didn’t get interesting until a few pages in, and the last est ups shows insane dilution for a newer car. It also seems like you guys were already fighting in several fronts alreadyThis thread:
https://bobistheoilguy.com/forums/threads/you-cant-change-your-oil-too-much.369632/
Not sure if you saw @The Critic's recent 1.5T UOA, but it had 9.2% fuel:
https://bobistheoilguy.com/forums/threads/2019-honda-cr-v-1-5t-mobil-1-ep-0w20-5-104-miles.370330/
The shutting off and disabling of the vehicle appears to be a result of the oil level getting extremely high. As noted in that thread, there's also an issue with valvetrain wear/failure that's associated with the high levels of fuel dilution.
Not all of them are going to dilute like crazy, it's very dependent on how and where the vehicle is operated. Short trips are not good, short trips and a northernly climate are worse.
Anyway what I got is, keep my OCI at 5k is fine. After next cycle I’ll test 91 fuel for level increase. I’ll keep an eye out of dip level as well, I hope most owners check their new oil level with the oil hot and not just cold, that affects readings too.
Also keep an eye out on Honda recalls it sounds like if there are that many people with the same problems
