2020 Chevy Equinox requires $131/quart fluid for transfer case!!
Yes, the T-case is basically a right angle gear drive, with an electric shift fork style actuator that connects/disconnects the T-case with the front right CV shaft.
The rear end kicks in/out with an integrated wet clutch.
Sounds to me like this transfer case (aka PTU) would run fine on typical 75W90 10 buck/quart differential lube.
The rear diff is a bit different since it has the clutch pack.
The nice thing about the 2018+ Equinox/traverse is the clutch pack and it's oil is in its own separate housing/reservoir. You have drain and fill plugs for the rear diff 75w90 and a drain and fill plug for the pentosin 11s.
I have a 2020 Equinox 1.5T AWD. I use Valvoline Transfer case fluid $apprx 20. And Mobil 1 75-90 $20. Are these prices you’re giving for work done in the shop? Your per qt amount is awfully high.
Yeah, the driveshaft is disconnected at both ends to decrease drag. And the 2 units are sourced from different makers from what I can find. The previous generation with the Haldex clutch unit at the diff had problems with sludge possibly from heat from the exhaust pipe nearby and would cook the pint of magic fluid.
Just like the exhaust pipes right on my Ford PTU (gone) - hope it’s much easier to change so that if another fluid is used - make it short and have a look. (Drain to a white bowl) …
I've been changing fluids in the 2020 1.5T AWD Equinox we bought recently. The gear oil spec'd by GM for the transfer case is AC Delco 10-4105 PTU Synthetic Lubricant that MSRPs for $131/quart. It's a GL-5 75W-90 oil. You can get it from Rock Auto for $73. And the t-case only calls for .53 quart. RA also lists Valvoline, Mobil 1, and Idemitsu synthetic gear oils as being compatible. Is there some ultra expensive additive that is required for something in this t-case that would make this stuff $130/quart? What were they thinking?
GM 10-4105
ridiculous
