Originally Posted by Trav
I put shims in a MK IV to correct toe and camber, that was 4 years and 35K ago and no issues whatsoever, it aligns spot on. The trick is selecting the correct shims, get that right and you have it knocked. Use the special wrench (buy or fab) to remove the 16mm head bolts and you don't even loose the hub bearing.
???? Kindly explain.
I have seen adjustable angular shims... where you nip-out the bolt-positions on the 360 degree shim so you can mount it behind the axle stub... i.e. between axle stub/spindle flange and bolting surface of the twist beam axle. You rotate the shim's two pieces to get the desired combination of toe-change and camber change you want. Seems to me that these can be used for a moderate amount of collision damage... or to "tune" a car, setting the alignment to a preferred set-up (from stock). Usually FWD cars are set up with a moderate amount of negative rear camber (to try to ensure that the car understeers at all cost). Now I am not suggesting that folks willy-nilly pick their own preferred rear twist axle alignments... but it could be done. Particularly if the rear twist axle is either a 'wee bit inaccurate from new, or for minor handling tweaking.
