Took the first “long” roadtrip in the Ascent, even though the wife has piled miles on like gas is free…
Anyways, went from near Muncie, IN to Yorktown VA via US-35 and I-64, ended up right at 1,450 miles round trip. Will be pulling UOA sample to see how dilution is doing since it was basically all highway. Ambient temps were 81-96* during drive time.
Flat highway, <65mph: stays 199-201 regardless of ambient, basically mimics coolant temp.
Flat, >65mph: pretty much tracks almost perfectly 2* increase for every 5mph. 70 is ~203*, 75 is 205*, and so on.
I-64 past Sandstone Mountain ((IIRC) where there’s 5+ miles of 7* incline: got as high as 226*F @ 75mph & about 3200rpm due to CVT.
In all cases, as soon as rpm drops, temps drop at least 2* every 15-20 seconds. Even the mountain passes had temps below 208* within about a mile after the peak. Steady 80mph thru Ohio had the gauge parked at 207*. Currently filled with @High Performance Lubricants PCMO 5w30 FTW.
It’s pretty apparent that even though the factory cooler is not visually impressive, Subaru knows what they’re doing!
